![]() | Home > Off Topic > Speed Camera Detectors |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
i have been thinking about the same thing for the past few months also,
nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111 ![]() ![]() ![]() |
Kam
probably the most expensive out of the two.. usually a good marker for quality/functions.. |
just checked on the web and the main difference is that the more expensive has radar gun warning as well . That is if you have time to slow down after you have been zapped or if the system has in fact warned you .
I've got a Belkan Euro 500(?) A bit old now but picks up everything. 2005 Zambezi TDV6 - Gone but not forgotten
Rob_J Member Since: 02 Nov 2005 Location: Usually flat out on the sofa with glass of vino Posts: 218 ![]() ![]() ![]() |
I've long thought about getting one...however....when I look at where I drive I know the GATSO locations....I know where the scamera locations are (always the same places anyway)....and I believe none of the detectors work effectively against laser....SPECS are pretty obvious any you have time to reduce your average speed....still not convinced it's worth it.......but then just watch I'll get knicked tomorrow |
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Have a read of
mark h Member Since: 09 Dec 2005 Location: north east where men are men and sheep are worried Posts: 19 ![]() ![]() |
hello all i have posted this below with referance to speed detectors this test was done by a good friend of mine just to see what the main differences were between two gps speed detectors hope it helps mark
Thanks Mark - good info! A couple of mates have the B2 as well and seem to be very happy with it. |
wow.. B2 seems like a good bit of kit..
not sure on that kam i know that it has the option of laser detection but im led to believe that these type are to be outlawed again after andy had tested both units i think that i will put the angel on ebay
