![]() | Home > General > PTI and iPhone problem - anyone suggest a solution please? |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Err, not a solution, but mine does the same.....
There are others who have said that it does work the same as your average Nokia... phones paired with the PTI should automatically reconnect once you've been through the initial pairing. |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Same issue there, seems that I have to re-pair the car and the iPhone after I have either switch the iPhone off or shut bluetooth off on the iPhone. If I keep the iPhone on all the time with never switching it off, I have no problem in the car....
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 ![]() ![]() ![]() |
Thanks to all of you who replied to my query.
Did you upgrade to iphone firmware 1.1.3?
JJF701 Member Since: 17 Dec 2007 Location: Norfolk UK Posts: 104 ![]() ![]() ![]() |
I upgraded my iphone to 1.1.3 and it made no difference at all. Keep us informed after the pti upgrade. |
fernandez77 Member Since: 10 Dec 2007 Location: cov Posts: 4 ![]() ![]() ![]() |
ez now
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
landroverstormer Member Since: 22 Oct 2006 Location: Somewhere close Posts: 325 ![]() ![]() ![]() |
I'm on 1.1.3 and currently drive an 08.5my and it works fine as regards BT connection and phonebook. Not checked any other functionality though. Not sure if this helps? |
Looks like we need to upgrade the PTI upgraded to the 08 software then. Never heard anyone say it works with the phonebook before so PTI software must be the answer.[/code][/list][/quote] |
I was in the apple store the other day and i ask the guy how to send text tones over from my N95 to the iphone? He said i can't BT on the iphone is only for the headset and not anything else RRS TDV6 Gone but still around
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Mine works! |
Is it a free update???? |
Jay,
