Home > Maintenance & Modifications > Bluetooth Factory Kit Install ( HHHEEELLPP )
Page 2 of 3 <123>
Kirbs
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Hi guys i have the VUB501151 blue tooth kit and have installed as far a i can. i have the steering wheel buttons fitted but have a plug on the end of the harness supplied marked up as AMP 962 112-3 and I'm guessing this should go to the amp under the drivers seat?
any help would be good, LR screen locked with LR logo, radio comes on but no sound.
pics as per cheers Kirbs
Post #561761 Sat Jul 21 2018 8:13pm
i guess you have the optical fibre going thru the BT module. BT module has no power and this is why screen is stuck on logo and you have no tunes.
If you were to rerouter the fibre back is it was you would get your tunes back
Post #561762 Sat Jul 21 2018 8:45pm
wiggs
The VUB kit does not actually come with a Bluetooth module .. you’ll need one of those to plug in the 54 pin connector Bluetooth Exchange www.bluetoothexchange.co.uk
Post #561763 Sat Jul 21 2018 8:46pm
wiggs
VUB kit has nothing to do with the fibre optic loop ..
Have you unplugged something on the most loop ? Did the radio work before you fitted the VUB kit ? Bluetooth Exchange www.bluetoothexchange.co.uk
Post #561765 Sat Jul 21 2018 8:48pm
Kirbs
thanks for the replies.
i have the nokia module fitted and have placed the optical fibre into it. I shall try putting it back into the radio.
i still have the issue of where to plug the end of the VUB harness.
cheers
Post #561777 Sun Jul 22 2018 8:40am
wiggs
Unfortunately it doesn’t make any sense
The VUB kit is for the landrover aftermarket kit .. it has a Bluetooth module .. but the module does not have an fibre optic connector in it
The factory fitted Bluetooth kit has a fibre optic connector on it . Bluetooth Exchange www.bluetoothexchange.co.uk
Post #561778 Sun Jul 22 2018 8:59am
Kirbs
thanks yes the kit has the module with it but i was informed that it needed the Nokia voice activated module also.
the RRS has voice command fitted and the mic in the overhead light unit.
still not sure where the end of the harness goes or if the Nokia unit is pre0installed somewhere else in the car, its not in the rear DS panel, cheers
Post #561779 Sun Jul 22 2018 9:10am
Kirbs
can anyone point me in the right direction, i think this kit must be for discovery.
i can't find where the harness female lock plug goes, to hook up with the amp.
any help much appreciated
Post #561879 Mon Jul 23 2018 7:10pm
Do you have the picture (comic) instructions ?
from
https://topix.landrover.jlrext.com/topix
If you don't PM me your email address as I have it on my computer.
Not that they are easy to understand!
Discovery 3 and RRS electrics are virtually the same
AMP is a brand of connectors used in cars. It don't mean it needs to plug into the amplifier.
I think this kit gets its power from the rear of the cigar lighter.
And has some terminals that plug into the rear of the small connector on the radio.
Pin
3 Red
5 Black
10 Yellow
Post #561883 Mon Jul 23 2018 7:52pm
Kirbs
Hi Andy yes you are correct about the power supply and the wires into the original plug these are all in place
the instructions supplied by LR are a bit vague you can mail me on pkwork106@gmail.commany thanks
Post #561889 Mon Jul 23 2018 9:13pm
Kirbs
Post #561890 Mon Jul 23 2018 9:14pm
blank.
Instructions emailed. (for what they are worth!)
Post #561893 Mon Jul 23 2018 9:45pm
Kirbs wrote:
Does this not plug into the square module that comes with the kit ?
Otherwise, does it plug into the back of the head unit. I can't see the connector pins from that angle.
I think the large LR radio connector should be unplugged and looped thru this accessory wiring and then back to the radio ?
Post #561894 Mon Jul 23 2018 9:47pm
Kirbs
End of plug showing pin arrangement
Post #561900 Tue Jul 24 2018 6:35am
don't know sorry.
suggest you tick off every item on the instructions (starting at 94 for RRS) that you have done.
And look closely at the ones you haven't and tell me what they are.
Post #561925 Tue Jul 24 2018 9:43am
Page 2 of 3 <123>
