Home > Maintenance & Modifications > Landrover Sliding boot floor.
Darren
2007 Range Rover Sport TDV6 HSE Java Black
Hi does anyone have one of these in there Sport. I am looking at putting one in mine as my wife will be putting a pushchair in and out and i think it would be easier for her. Would like to know what they are like to fit as my local dealer doesnt know, and also if it rattles if nothing is in the boot.
Hope you can help.
Regards
Cool
Post #133323 Fri Aug 17 2007 6:26pm
Josh
I think one of our Dutch members has one. Saw some pictures somewhere on here not long ago. TDV6 - gone
TDV8 - gone
Post #133350 Sat Aug 18 2007 8:53am
jappie911
Netherlands 2007 Range Rover Sport TDV8 HSE Java Black
Yes, that was me..
I had it ordered without seeing it, for using it for my RC heli's.
The thing is great quality, but also very heavy, and big.
Also the floor is much higher, (think about 10 cm.)
And it does not come out very far.
Did not use it much until now, and put it in the garage right now, then there remain only 2 rails.
It goes out about 10 cm more then you see now.
[/img]
Post #133384 Sat Aug 18 2007 4:08pm
Darren
Thanks for the reply. Can you still get to the under boot floor storage for the tow ball, and also are the rails screwed thru additional holes made in the floor or do the rails screw into the load tie down D ring holes ? I guess you can also remove the platform ?
Thanks
Post #133385 Sat Aug 18 2007 4:27pm
jappie911
Yes you can remove it, also needed for getting under it for tow-ball etc..
Because normally it does not slide far enough.
When you slide it outwards, and lift it, then you can remove it, (heavy)
Im not sure but I think they had to make extra holes for the rails.
Post #133439 Sun Aug 19 2007 3:51pm
jappie911 - would it take the weight of a person sitting on it when pulled out? 2005 Zambezi TDV6 - Gone but not forgotten
Post #133447 Sun Aug 19 2007 5:44pm
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Every member here with the exception of Envoy I suspect VA. Rolling with laughter You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #133454 Sun Aug 19 2007 6:15pm
aljo
Shocked Shocked Shocked thats slander !!!! Shocked Shocked
not his fault hes a f*t tw*t Whistle
Post #133455 Sun Aug 19 2007 6:48pm
