![]() | Home > Technical > SQUEAK FROM REAR BRAKES !! |
You might have run over Robin Sunpower! Seriously - it could be a small stone stuck in between something or your handbrake not fully disengaging. The weather might be a cause in some way. Not much use I'm afraid. |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Welcome to RRSPORT Big Bad Range |
How timely and appropriate!! Sound advice, Martin! ![]() ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
It is quite normal for such a large car's brakes to groan under slow manouvering, however if it is a high pitch squeal there could well be a piece of grit wedged in the caliper face, it will work itself out within a week's use. L319 D4 HSE
BIG BAD RANGE Member Since: 24 Nov 2005 Location: KENT Posts: 64 ![]() ![]() |
HI I TOOK THE RANGE BACK TO DEALER AND THEY STRIPPED THE REAR D/S CAILIPER AND GREASED IT ETC SEEMS OK AT THE MO.......... |
Stop SHOUTING at us!!!!!!! But it's amzing what a bit of lubrication can do. 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
BUT HE IS THE BIG BAD RANGE, DOGGONE IT!
Take a hint, BBR. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Here is what my dealer did to stop the squeak on my brakes, according to the service invoice: "Checked and found excessive brake dust on calipers. Removed excess brake dust". The squeak is gone. |
as i stated before my squeak from the rear brakes/suspension did go but has now come back it comes and goes if you rock the car left to right and roll back on creep it is there sometimes...........any thoughts gents...... |
out of interest how many miles have you covered in the car? L319 D4 HSE
