Home > General > Aux socket
Geordiehillbilly
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Aux socket
Does anyone else get "feedback" if they plug anything into the AUX socket in the centre box? I get it if I even put a cable in and I've tried a few. Suppose another thing wrong to take back to the dealer......
Post #5671 Wed Nov 23 2005 7:03pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Not tried it yet as I'm still making my way thorugh my MP3 discs! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #5684 Wed Nov 23 2005 10:49pm
grommet
United States
Many are using it fine... works well.
The only flaw is that the head unit has no relative volume control on AUX, so you will go deaf if the Navigation voice pops on or you switch audio sources... since many devices will require higher than usual volume.
Post #5698 Wed Nov 23 2005 11:53pm
djsaad1
United States 2006 Range Rover Sport Supercharged Java Black
if you hookup an ipod to the aux can you not control the volume through the ipod?
Post #5699 Wed Nov 23 2005 11:59pm
grommet
United States
The volume is too low with most devices' maximum volume, so you need to jack the volume up on the head unit far higher than usual. (The head unit should offer an AUX specific volume offset so you can match levels.)
Post #5700 Thu Nov 24 2005 1:02am
