Home > Maintenance & Modifications > Got me Parrot in the car!
Tim in Scotland
Car is back from the dealers' electrician and now has the Parrot CK3100 Hands free kit. It isn't sited on the dash in an exactly attractive position - I will be working on the bit myself with a small relocation and some velcro but works brilliantly, picks up my V3i within seconds of getting into the car and can support up to 5 mobiles at once if necessary (so far we have had 4 phones all paired to it at once). I now have to spend the evening talking to the voice activation to get that lined up too. It's quite a sophisticated piece of kit and will give caller display, reads the mobile phone phone book and displays the data on its screen, mutes the ICE when you make or receive a call, displays the callers name on incoming calls and will work with any B/T equipped cellphone. Total cost incl fitting and a free gift magic tree type car air freshener from the dealer was £285. Sound reproduction of the phone is crystal clear and the microphone is nicely integrated into the A pillar. And I you are buying an SE or S without the PTi it is cheaper than having the LR system and it's problems as a factory fit extra.
Will post some pics later.
Now all I need is a piece of newspaper, a cuttle bone and a bowl of Trill an my parrot will be truly happy! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #113680 Tue Jun 05 2007 6:11pm
flydive
Got the Parrot in my RRS too. Nice piece of kit it seems.
Only problem with my Nokia N80 is that it does not read the phonebook from the phone, I had to transfer the contacts manually.
Post #113716 Tue Jun 05 2007 8:32pm
Tim in Scotland
Interesting as it reads my V3i's phone book within seconds of pairing 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #113725 Tue Jun 05 2007 8:52pm
Cliff H
I have had the 3100 in my van for over a year now and it has always been excellent.
Yours sounds a bit expensive though Tim.
Mine was £150 fitted by local expert.
The 3100 is about £80 to buy plus on the RRS it will need another wiring harness around £20
Post #113734 Tue Jun 05 2007 9:04pm
Tim in Scotland
Several people have said this to me Cliff............................. Big Cry Big Cry 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #113739 Tue Jun 05 2007 9:16pm
salesman
Scotland
Not sure about 3100 but a Phone guy we use wont fit parrots to sports because the wiring kit parrot supply does not connect & you need to take the centre colum out (from gearbox back) to get into the rear of stereo . He will fit them to Flanders & sports
Post #114124 Thu Jun 07 2007 3:38pm
Tim in Scotland
The dealer did it "in house" as they have experience of doing them on D3's and Freelanders but this was the 1st RRS they had done - Salesman I'm relieved by your comments about the complex nature of the Sports centre consol, it explains why I was basically charged for 1.5 - 2 hours of labour if it is that complex. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #114143 Thu Jun 07 2007 6:34pm
Gary
Mine was fitted afew weeks ago, RRS electrics are fibre optic so needed adaptor took longer to fit, Parrot, works perfectly!!
Post #114149 Thu Jun 07 2007 9:20pm
fibre optic Shocked really Question
Post #114150 Thu Jun 07 2007 9:23pm
Gary
Yep, apparently the HSE that doesn't have the factory BT fitted has F, Optics SE and below doesn'y???? Shocked
Post #114151 Thu Jun 07 2007 9:28pm
Tim in Scotland
Yup I'm very pleased with mine although the location it was put in isn't that nice, the techy installing it screwed the mounting foot into the dash cubby (and through the rubber mat so now I cannot remove the mat!) where HSE's have the satnav screen. I would have preferred it to have been fitted flush on the dash with some velcro or double sided sticky pads (as shown in the installation instructions) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #114165 Thu Jun 07 2007 10:06pm
skidmark
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
would it have been better to have the PARROT on your shoulder for when you go back to the boat ????? if i offend and i know you sorry if i dont TUFF
Post #114272 Fri Jun 08 2007 2:29pm
Tim in Scotland
All that birds Censoredt fairly stains the uniform jacket, so I think I'll leave it at home thanks Skidmark. Also handsfree isn't required on the ship! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #114322 Fri Jun 08 2007 6:35pm
theo
2007 Range Rover Sport TDV6 HSE Java Black
Don't forget to update your Parrot regularly (very easy with BT connection): http://www.parrot.biz/uk/support/downloads
Post #114324 Fri Jun 08 2007 6:47pm
Tim in Scotland
Thanks for that Theo. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #114330 Fri Jun 08 2007 6:55pm
