Home > Off Topic > DIY Advice please
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
DIY Advice please
I'm pretty competent but I have an iissue where a rawplug fixing has come out of the wall (plaster and breeze block construction) and now the hole is much larger, therefore I need to fill it somehow with something strong enough to bond with the substrate and the plug and hold up the fixing (a curtain rail)
Any ideas? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #4826 Fri Nov 04 2005 6:10pm
Either try a larger more substantial raw plug or fill the hole and start again. Always drill a slightly smaller hole than is reccomended for the raw plug in question to be used.
Post #4827 Fri Nov 04 2005 6:21pm
RRUK
They don't make raw plugs this big! The hole is about the size of a 20p coin diameter.
I know I need to fill the hole, just not sure what material to use that will do the filling part but also be strong enough to hold the fixing again.
Back to the floor Confused L319 D4 HSE
1982 Series 3 SWB
Post #4828 Fri Nov 04 2005 6:45pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Try filling it with normal filler (use the powder that you mix yourself as it is much better than the ready mixed). Fill your hole, then push in a new plug while the filler is still wet. Let it dry for 24hrs. Then it should be good enough put a screw back into it. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #4832 Fri Nov 04 2005 10:16pm
Tim in Scotland
Or you could glue some match sticks into the hole to reduce it's size to where the rawlplug will fit, or you could entirely fill to hole with glued matchsticks or small dowl, long enough to completely go back to the breaze blocks then use a self tapper to attach the curtain rail - my brother cured a hole in my walls using this method when my curtain rail fell out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #4862 Sun Nov 06 2005 8:01pm
noddy and bigears
big hole
fill it with gripfill or no nails works quite well just needs a bit more time to set
Post #4942 Mon Nov 07 2005 10:44pm
Mr Bean
A Sand and cement mix would do the job. Gripfill stuff ok but need the quality stuff. More exspensive tubes not the 99p screwfix no nails.
Post #4948 Tue Nov 08 2005 1:33am
RRUK
Thanks for replies, fixed it with filler and a large plasterboard plastic fixing with a deep thread on it, seems to have done the job. L319 D4 HSE
1982 Series 3 SWB
Post #4975 Tue Nov 08 2005 6:38pm
