Home > Technical > EPB
Biggles
EPB
Has any body tried the emergency routine with the electronic park brake yet.
I did this last night and boy does it work. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #4799 Fri Nov 04 2005 2:28pm
Re: EPB
????? I'm lost , what exactly is this
Yours confused
MDP Confused
Post #4801 Fri Nov 04 2005 3:19pm
Biggles
If you pull and hold the hand brake while moving (I suggest you try it at a slow speed) you will find the car will do a very very controlled emergency stop for you. As you perform this you will hear the ABS braking system working, which gives of a similar sound to the HDC when it is being used. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #4811 Fri Nov 04 2005 3:58pm
Shocked Shocked Shocked Shocked Thanks
Post #4812 Fri Nov 04 2005 4:03pm
Biggles
Leading on from this I often wonder how many people with ABS brakes press as hard as possible to stop quickly.
When in fact you need to release some pressure on the braking system to have a more effective and cotrolled stop. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #4813 Fri Nov 04 2005 4:09pm
So it's braking at all four wheels when it does this? Doesn't just jam on the handbrake, I hope? Shocked
Post #4818 Fri Nov 04 2005 4:33pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
At least it's not like the old RR's where the handbrake was straight off the back of the Transfer Box, no WAY you could ever yank that in an emergency.
The traditionalists of the marque all said that LR products were going too 'mainstream', what with the arrival of the Freelander being more car like, the P38 RR having more car like tendencies and electronic gizmos, and now, the L322 not even having a ladder chassis ! Goodness gracious! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #4839 Sat Nov 05 2005 6:27pm
Tim in Scotland
Ho Ho Ho what fun the EPB is on ice!
Quiet back road, plenty of ice on one side and I had a play with the EPB this afternoon................................ this is a magic piece of kit and soooo clever!
With the 2 nearside wheels firmly on the ice and doing about 40mph down hill I eased off the gas and yanked on the parking brake.................... pulled the car up in about 60ft straight as a die and without any locked wheels, even with 2 wheels on the ice. I don't think I'll try it with all 4 wheels on the ice though, I reckon the car would spin just like any other vehicle braking hard on a slippery surface! The EPB is a very effective piece of kit. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #5460 Sat Nov 19 2005 5:42pm
Biggles
Tim,
I can't wait to see some proper snow or ice. I know just the place to try this out without any fear of damage due to loss of control.
Cant Wait. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #5494 Mon Nov 21 2005 12:23am
noddy and bigears
ABS
biggles are you sure you should ease of the pedal the main downside to abs is just this thats why manufactrures are changing to eba thou i do stand to be corrected Laughing
Post #5948 Fri Nov 25 2005 8:58pm
