Home > General (L494) > Cooler to Fridge upgrade on 2018 facelift model
Woppyman
United Kingdom 2012 Range Rover Sport Supercharged Autobiography Siberian Silver
As title says. Swapped over the passive cooler for the fully fledged refrigerator on my L494.
Had to remove rear climate facia, 4 bolts behind it. Hockey stick trim and two side trims that go up centre console. I also took out the front climate screen but this was not necessary. Then it was a straight swap. Tricky to get cigarette lighter plug off but once done all easy.
Here is a pic of the cooler vs fridge. Cooler only has one setting, both blue leds on or off. Fridge has two settings, one LED, Two LED or off.
Also full fridge is slightly smaller inside to allow for compressor to be located. However fridge went in easier than cooler came out.
Will let you know how it keeps my beer cold
 Evoque HSE Dynamic
5.0 Charger MY12
Post #647337 Wed Mar 19 2025 1:48pm
daxmatt
This is good to know, How can you tell the difference from the outside whether its a cooler or fridge ?
Are the buttons or led's different ?
Do you think this could be retro fitted to one without a cooler ?, is the loom/plug there ready to go ?
Post #647363 Fri Mar 21 2025 7:38pm
Woppyman
Its not easy to identify them. They look identical apart from the internal depth. The easiest way is to press the button on the top. If the only options are 2 blue LED's on or all off then you have the cooler. If when you press the button on the top it cycles through one LED, two LED then off then you have the fridge. Also the fridge has a slight vibration that you can feel if you put your hand on the top of the cubby hole lid. Evoque HSE Dynamic
5.0 Charger MY12
Post #647364 Fri Mar 21 2025 8:02pm
daxmatt
Do you think it can be retro fitted , are the plugs there ready and waiting Smile
Post #647365 Sat Mar 22 2025 8:23am
scrumps
Hi,
Yes it can be retro-fitted.
One of my l494’s arrived without the fridge I specified (and paid for).
The dealer fitted a fridge before handover.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #647366 Sat Mar 22 2025 8:59am
daxmatt
Post #647368 Sat Mar 22 2025 10:45am
