Home > Maintenance & Modifications > intake manifold repair issue
palawandiving
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Been trying to replace the drivers side intake manifold on my L320 TDV6 3.0 over the weekend & run into numerous issues....
Stripped the air intake, cooling system, ECU, released the EGR valve a little... got the Common rail out, injectors & all the bolts, brackets from the old intake manifold off. Got the really difficult brackets off the back with the double nuts on the bolts for the brackets.
Got the manifold loose and can raise the front above the plastic timing cover no problem. Can't seem to raise the back enough of it enough to get past the chain underneath.
Does anyone know how much needs to be stripped out? There are still 2 steel fuel pipes sitting on the back of the manifold one goes into the back of the common rail, the other goes into the injectors. They aren't helping things - but feel like I need to do more.
Forgot to put the car in service mode so didn't lower the suspension which apparently gives more room in the engine bay at the back. Any ideas how to put it in service mode with the engine disabled?
Any help would be much appreciated - been a horrible weekend - what a horrible job
Post #647137 Sun Mar 02 2025 9:14pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
See LR time on you tube where he shows how to do it with JB weld an no removal KISS
Lowering the car will not give more room in the engine bay Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #647141 Mon Mar 03 2025 10:07am
