![]() | Home > Technical > ACE ecu |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4441 ![]() ![]() ![]() |
They can be used 2nd hand, but need the correct firmware installed |
Reno Member Since: 12 Oct 2023 Location: loughborough Posts: 7 ![]() ![]() ![]() |
Can you elaborate, my understanding was that the CCF files automatically detect the correct ECU is installed. Not sure what you mean by firmware.
The actual firmware/software installed into the ECU. It's different for 2.7/3.6/4.2 models etc. Also different for different model years too
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
I believe the module has a choice of "tunes" available when it's made and the correct one for the vehicle is selected when it's first installed. So if you have a TDV8, for example, getting a second hand module from a TDV8 should make things easier, especially if you can find the right year.
