![]() | Home > Technical > New owner - a couple of niggles |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Rear door locks are on ebay ..common problem Always listen to old people or when they die you will live on in ignorance.
Jack4Gracie Member Since: 19 Feb 2025 Location: North Yorkshire Posts: 7 ![]() ![]() ![]() |
Thanks. Yes, after a web search clearly the rear door locks are a common issue. So, for solutions, there are £35 Bay locks, Ridex brand from literally dozens of sellers, plus the Autodoc website.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4441 ![]() ![]() ![]() |
I've fitted a few aftermarket latches
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 222 ![]() ![]() ![]() |
I've had all four replaced at my indi over the last 4 years one of the rears was faulty as soon as I purchased it , I presume that genuine LR parts were used but having checked the invoices they were all around £175 Inc labour, £400 does seem very expensive. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
I replaced the O/S/R lock/catch on mine sometime ago, the car is a very late 2012 A/B MY13 keyless entry/passive start etc. The Part No. for the genuine L/R lock assy. was LR091345 which with your year car is the one I would think you need although I can't be certain. Personally I would not buy the cheap Chinese crap off ebay as it is cheap for a reason, the other issue is half the muppets selling this stuff don't actually know if it fit's your particular vin no. either. Cheers Col |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 135 ![]() ![]() |
I’ve done an Evoque one and they all use the same part if I remember correctly. If you’re not feeling up to it, I’d send it to the specialist - actually who is your specialist? I’ve not done an RRS one but the Evoque one can be done in under an hour. I’m sure someone like Disco Mikey can give you an accurate timeframe on how long it should take to do one.
If changing a door lock which can be done standing up rather than under the car is a problem for you then heaven help you if you need to change the crankshaft position sensor or pay the £2000 to get it done Always listen to old people or when they die you will live on in ignorance.
Thanks to all for the comments - much appreciated.
