Home > Technical > SDV8 strange HP fuel pump noise
Astanavits
France 2013 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Hello everyone
I have a 2014 SDV8
the other day when opening the hood while the engine was running I noticed a strange noise coming from the CP4 injection pump, like a timing chain tensioner noise but it comes from the injection pump everyone knows that these pumps are fragile the noise is really audible when the rpm drops back to 1000 rpm
I checked the entire fuel system:
-pump relay R8 in the trunk
-the fuel sender in the fuel tank (stage 1)
-the lift pump (stage 2) under the engine ECU i have LHD.
-replaced the fuel filter twice
-common rail pressure regulator left
-common rail pressure sensor right
-FCV fuel volume control valve on the top of the pump
I found several testimonies from owners who changed the injection pump 800€ because this noise but the noise is still present after replacement
I also discovered that if you disconnect the FCV valve on top of the pump when the engine is at idle the noise disappears immediately
disconnecting this valve brings the pump to its maximum operating pressure, I don't understand why the noise disappears at high pressure, does anyone have any ideas?
I'm going to post a video of the noise, can the owners of TDV8/SDV8 4.4L tell me if it's normal? or if I'm paranoid?
Thanks in advance
Post #646960 Tue Feb 18 2025 4:36am
Astanavits
Another exemple
Post #646961 Tue Feb 18 2025 4:37am
Astanavits
Another one
Post #646962 Tue Feb 18 2025 4:38am
Astanavits
Even a 2019 MY ??????? Listen at 0:59 ???? im not mad 😂
Post #646964 Tue Feb 18 2025 5:31am
Astanavits
Update: Today I received and installed the stage 2 pump bosch 0986580131 / LR023043
problem not solved but the new pump seems to build up pressure faster and I can no longer hear the pump from inside the vehicle ,Obviously the pump is in poor condition, there was black fuel in the pump, I imagine that the pump in the tank must be in the same condition
next the in tank fuel pump
Post #647290 Sat Mar 15 2025 10:05pm
