![]() | Home > Faults & Fixes > Scraping/Grinding Sound |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Sounds like a small stone stuck in around the brake pad area. If you can get an air line in there try blasting some area around the brakes. The metal noise will be the backing plate and stone coming into contact.
mitdan27 Member Since: 30 Sep 2020 Location: Cannock, Staffordshire Posts: 11 ![]() ![]() ![]() |
Thanks for that, fingers crossed it is something fairly trivial like that rather than something more sinister!
Had it all apart this afternoon, cant see any signs of scoring on the disc or pads etc, only thing I could see is a scored area around the edge of the backplate which had gone shiny and almost cut through in places, so that looks like the obvious issue.
