Home > General (L461) > WIRELESS CHARGING PLATE
maurizio_italia
Italy
Hello, often when I put the iphone on the charging plate of the RRS 2024 Dinamic if I see the logo that warns that it is not charging, I have to try a few times before it works. It happens to you too? thanks
Post #646690 Tue Feb 04 2025 3:56pm
Tizzy
Mine seems to work fine with an iPhone 14, gets quite hot though and the charge rate is pretty slow
Post #646695 Tue Feb 04 2025 8:55pm
scrumps
Hi,
Mine works fine - as long as the phone is forward of the rear raised lip and is flat in contact with the mat.
Charging indicator on the top left of the touchscreen works well too.
Iphone 12 - 24MY AB.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #646697 Wed Feb 05 2025 9:59am
FunkGogh
Italy
HI
Maybe your phone cover is too thick? Try without
Ciao
Post #646707 Wed Feb 05 2025 3:38pm
Meshan
There are also different standards for charging
Phone and charging plate need to be compatible.
Qi is the most common. L320 Range Rover Sport 2008
3.6 TDV8
Post #646708 Wed Feb 05 2025 4:27pm
maurizio_italia
Italy
Hi, I use an iphone 14 max and specific cover for the wireless charge "mag safe", I also tried to remove it. I have to make several attempts before the power-up tells me it is active, it never works just by leaning on it. Nothing serious but sometimes it is turned on and off continuously and this is not good for the phone battery. I will report it at the first check.
Post #646735 Thu Feb 06 2025 4:35pm
jorosa
My phone also cuts in and out of charging, this did get better with one of the PIVI PRO updates, but the worst thing is the heat it generates as on my 1.5hr commute the phone shuts down as it has got too hot!
In some Porches they pipe in an aircon vent to prevent this - I have resorted to an old skool cable!
Still love the car though! 2024 Range Rover Sport D300 Dynamic SE in Varesine Blue
2019 Mercedes E Class Estate E350d (Gone)
2017 Mercedes C43 Cabriolet
2013 Jaguar XF Estate 3.0d (Gone)
2016 Mercedes CLA Estate 220d (Gone)
2006 Range Rover Sport 4.2 Supercharged (Gone)
Post #647327 Mon Mar 17 2025 9:42pm
