![]() | Home > Technical > Tyre pressure valves |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
What I think you may need to check is, TPMS was a mandatory fitment to new models introduced after late 2012 I think, so it may be that if you present the car for MOT with it not working it may well be a fail as I think it now included in the MOT test.
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 41 ![]() ![]() |
If it has TPMS and you fit wheels without TPMS valves, or the wrong type of valve you will get a fault.
