Home > General > Tailgate (yes, another one).
GrumpyPenguin
I have a 55 plate RRS 2.7 with a split tailgate.
I cannot get the tailgate (just to top or all of it) to open.
I've tried the "hold the buttons in for 5 sec's" on the dashboard, the remote (car locked & unlocked, ignition on/off) & the push the tailgate firmly shut & push the release buttons.
It appears to be mechanically shut & I don't think anything is caught in the latch.
No error message on dashboard & no fault code when using the ODB port.
Fuse's also checked & OK.
Any suggestions please ?
Is there a mechanical release anywhere ?
(I've done a search through this forum & cannot find any suggestions that I have not tried).
I'm beginning to suspect the sensor on the latch not telling the BCM that the tailgate is in fact shut so the BCM thinks it's open ? It has in the past occasionally given a "tailgate open" error on the dashboard & an "open & firm shut" would clear it.
TIA.
Post #646022 Tue Dec 31 2024 6:59pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
See my post:-
https://www.rrsport.co.uk/forum/topic61106.html
Good luck!
Post #646042 Thu Jan 02 2025 11:05am
If it was the sensor/switch in the latch, you would get a dashboard error message.
Usually firmly pushing on the tailgate, at the bottom middle helps, but I suspect you tried that.
If all else fails you can remove the trim from the rear, and see if you can open it.
Was the glass hatch working before ?
Post #646049 Thu Jan 02 2025 12:30pm
d-9
Probably thinks the lower tailgate is open. Open it and close it again.
Post #646054 Thu Jan 02 2025 6:39pm
Disco_Mikey
I've seen a few broken wires in behind the plastic/rubber coating on the glass frame before
The switch can be removed, unplugged and wiring bypassed to test temporarily
Post #646055 Thu Jan 02 2025 9:08pm
