![]() | Home > Technical > Battery Confusion (i don't even have start stop) |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
Seems to me that whoever is calling batteries stop/start really means they are AGM batteries 2015 L494 SDV6 3.0 HSE Loire Blue
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
As the car is 14 years old very unlikely it still has the original battery fitted and someone replaced it with a AGM type battery, as I think you may find L/R started fitting AGM type from the factory around 2011/12 on the diesel vehicles not petrol version though. Although I did fit a Varta AGM battery to mine which is also described as stop/start, although it was not necessarily a requirement for a AGM it has lasted 8 years so far.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
About £90 on ebay Always listen to old people or when they die you will live on in ignorance.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
Worth checking the alternator is ok, too. |
