Home > Faults & Fixes > Compressor dead
Gerryd
Scotland 2009 Range Rover Sport TDV6 HSE Santorini Black
Compressor dead
How do I check if my amk compressor is dead I have suspension fault after 15 seconds of start up I stupidly deflated all with gap iid tool. And it's now on bump stops I attached 12volt to power supply and it does nothing not even a click is there a better way to check compressor
Post #645950 Sat Dec 28 2024 4:32pm
Karlp606
Check under the boot carpet, take the spare wheel out and inspect the compressor - could be a fuse also.
If it is dead you can get a replacement on ebay for £120 and its a easy DIY job to swap it out.
Post #645986 Mon Dec 30 2024 1:05pm
Gerryd
Thank you but mines is a l320 so not in boot
Post #645987 Mon Dec 30 2024 1:14pm
