![]() | Home > Technical > L320 ‘Suicide Pause’ Help - Possible Fixes or Cures? |
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 64 ![]() ![]() ![]() |
Excuse my ignorance, but was is "suicide pause"?
CarbonTrac Member Since: 05 Jun 2018 Location: Leicestershire Posts: 31 ![]() ![]() ![]() |
Suicide Pause was how it was described to me, and from my experience with it the name suited the feeling so I have continued to call it this.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 921 ![]() ![]() |
That's the only thing I will not miss on my recently sold Sport. Roundabouts were a |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
I try not to floor the accelerator but only go say 2/3 then lift off and then floor the accelerator - works perfectly. Sounds a bit slow when you read the action but when doing it, it almost sounds logical.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9037 ![]() ![]() ![]() |
I just use the paddles and change down as I approach the roundabout. It's annoying to have to do this but it does solve the issue for me.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 430 ![]() ![]() ![]() |
Mine picks up instantly in all situations .I suggest you check/change the gearbox oil/filter Always listen to old people or when they die you will live on in ignorance.
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
I just put the gearbox into Sport mode. That cures it for back to back roundabouts and such. I did a gearbox flush last year and it made little difference. 2018 Telsa MS
