![]() | Home > Maintenance & Modifications > Normal Ride height with Codes |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 166 ![]() ![]() ![]() |
Good evening all,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
Any help? I believe a blocked intake filter/silencer has been mentioned on a few post previously.
Cheers Col
Forgot to add this one for the first code.
I think it is behind the n/s load space trim, not the rear lamp, but not totally sure. I think a new L/R one is complete with the pipe so you might need a push fit joiner to splice it in to save removing the whole pipe/filter assy. thing.
Once again Thanks Col
