Home > Technical > Retrofit TV
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Retrofit TV
Hello,
For what its worth, probably a dumb choice.
Id like to think I could retrofit a TV module to my Autobiography Sport 2010.
I have factory fit rear entertainment as standard and wondered if I could loop into this system, seeing as though I have the fakra and fibre optic for the rear screens, is it possible to add TV to the system.
I have the 3x antenna modules which would live in the drivers side rear window, as I bought a job lot when I was chasing the lack of DAB reception a few months ago.
I understand Id need the TV module, that sits further forward of the DAB module on the left side of the boot area.
Am I being dumb thinking I can add the TV in?
or would I need to run a separate fakra and fibre optic to the headunit? like in the guide that was created a few years back which someone was kind enough to create on here.
If its too much hassle, its not too much of a problem, as I understand the reception is sketchy anyway so I'm lead to believe?
Also, whilst on the subject of retrofitting....
I have programmed timed climate to my display screen and it turns on the FBH every time. I see a kit on ebay for £159 which is sold as a kit for the L322, the guy asked me what colour plug I had in the offside boot area space, Id responded it was black, but thats the last I heard from him.
Again, is there a kit I can buy or do I need to buy the parts individually, I understand its a Telestart T91.
Cheers in advance
Dean
Any thoughts?
Dean
Post #645308 Mon Nov 18 2024 9:35pm
Might help, but unless TV programmes have improved since I lived in the U.K I wouldn't bother, probably more trouble that it's worth, unless you keep the engine running it will shut down after few minutes.
https://drive.google.com/file/d/15mLqoCdYr...drive_link
Post #645311 Mon Nov 18 2024 9:52pm
RallyeSport
Hi Col,
Yes I'd seen the 'how to' guide.
From what I can see if I already have Rear Entertainment I need a lead to add into the system.
I just wondered if anyone in the same situation as myself had successfully added it?
I'm not sure however like you say the worthiness of it, due to crap reception.
Id be more interested in adding DAB+ which I understand others have done, which would be more beneficial to myself.
Dean
Post #645317 Mon Nov 18 2024 10:50pm
