![]() | Home > Faults & Fixes > No heat from the passenger side air vents 2008 TDV8 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Heater matrix gets blocked.
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Thanks for the reply, will investigate, are these expensive items to replace? |
The Nissen replacement unit for the TDV8 3.6 is £80 , time to investigate if its doable 🫣 I have found videos on YouTube explaining how to flush the matrix using radiator flush solution but by the time I’ve invested in the 3/4 inch pipes and a small electric pump etc fitting the replacement nissen unit would be the better option. Fingers crossed I’m able to, thanks for pointing me in the right direction |
