Home > General (L494) > Error Messages - water in fuel..bonnet open…etc
TJRRS
Hi
2014 L494 with 95k on clock has started throwing up a number and these error messages…..water in fuel. Bonnet open and low coolant levels. Looking at previous forum threads it seems the issue is related to the headlight earth straps. However I am now unable to lock the vehicle as the alarm keeps tripping. Is this normal for issues with the headlight earth straps or is there something else going on which is tripping the alarm.
Thanks in advance
Post #644940 Mon Oct 28 2024 5:45pm
Red Arrow
Will be the earth straps, i think drivers side one shows those faults from memory Thumbs Up
I had exactly the same with ours .
Post #644966 Tue Oct 29 2024 10:03pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Passenger side under front arch liner earth stud corroded. Drivers side gives ABS and associated faults. Simple check, see which Headlight isn't working and that's your side to look at. I'd recommend doing both sides as sooner or later you'll be doing the job again!
Post #644967 Tue Oct 29 2024 11:50pm
Baka06
Re: Error Messages - water in fuel..bonnet open…etc
TJRRS wrote:
Hi
Thanks in advance
I've just had the exact same issues. It was all resolved with the earth strap fix. Thumbs Up
Post #644999 Thu Oct 31 2024 12:43pm
