Home > Technical > Battery Warning Light
Daveybunting56
Hello all, I am new here however I have owned several RRS’s love them and never really had many issues with the ones I have had.
My current one however has the battery warning light on and has always had it on since I got it, the voltage seems ok when I clear the fault but when the light comes on again a minute later the voltage drops. Everything has always worked in the car for the past 6months other than the stereo which goes into low power saving mode.
Can anyone please advise what I should try and do to fix this issue.
TIA
DAVEY
Post #644571 Sun Oct 06 2024 1:02pm
you probably want to run some checks, but I expect you will need an alternator
Only fit a genuine one, as others give all sorts of problems, like you have now.
Post #644572 Sun Oct 06 2024 1:32pm
gogsy1956
I'm suprised you have got away with it for soo long as it is,,, once they start to be unreliable the alternator will go south very quickly. I've had the same issue with mine,,, checking the voltage is not a definitive test,, you need to check the output current as well.
Whatever you do,,, do it quickly before you are left stranded. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #644578 Sun Oct 06 2024 4:08pm
