Home > Wheels & Tyres > Correct tyre pressures
MaxDog197
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Ive fitted 265x50x20's to my L320
Currently running on 40psi and the ride is fine, is there a more suitable pressure recommended ?
Thanks
Post #644477 Sun Sep 29 2024 6:13pm
NoExpert
What it says on the door would probably be best.
L319’s and L322’s with 255/50R20’s run 2.3/33F and 2.5/36R. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644482 Mon Sep 30 2024 6:27am
there is a label on the inside of the drivers door.
Check the pressure against your tyre size.
The pressures nearer the top are for light load and will be more comfortable
Post #644483 Mon Sep 30 2024 10:19am
That tyre size was never a option on the L320 so won't be listen on the door label, but personaly I run 33 front and 36 rear as suggested on 275/45 x 21" and works ok for me.
Post #644484 Mon Sep 30 2024 10:45am
MaxDog197
Yes., the tyre size isnt included on the door matrix.
Post #644485 Mon Sep 30 2024 11:04am
supernatural
Australia
Has anyone here experimented with different pressures for off-road vs on-road driving?
Post #644514 Thu Oct 03 2024 3:52am
Very few people take their RRS off road these days (there used to be a few more on here but they've drifted away over time).
I've never bothered changing tyre pressure when going off road. The traditional idea of reducing pressures (airing down) isn't feasible with the relatively short sidewalls on the tyres that fit on the RRS. You'd risk sidewall pinching if you dropped them low enough to make any difference to the contact patch. There is a school of thought that you're better to increase air pressure in order to keep the sidewall more rigid so that you don't get pinching on roots/rocks. A chap did a rocky route in South Africa and did just that with his Disco 4 tyres.
For the stuff I've done (admittedly none of it extreme in any sense), I've just run my normal road pressures. I do generally run my tyres a couple of psi higher than the door card because I run 255/55/19 and find they wear better with a touch more air (the vehicle is designed for 255/50/19 (or 20inch equivalent). I've never been stuck (close a couple of times when on my own on muddy farmland but both times self-recovered just by using the rock back-and-forward technique) so it seems to work so far. 2012 SDV6 - it's missing a couple of cylinders
Post #644520 Thu Oct 03 2024 10:07am
