Weird wet patch around D pillar in boot…
So after heavy rain last night the rear D pillar around where the rear speakers are is quite wet, I’ve already fixed the sunroof drain on that side and it’s draining, all the usual areas where the sunroof leaks is dry , above the grab handle where the headlining is etc. it’s only wet on one side the passenger.
I’ve attached a photo where it is wet I’m not sure if the rain is getting between the body and top boot area where the spoiler is , can anyone help?? I’ve circled the wet areas in yellow.
Thu Sep 26 2024 10:33am
Karlp606
Thu Sep 26 2024 5:11pm
Grimble
I would check again your repair, that's exactly the area that gets damp when the drain becomes detached.RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Fri Sep 27 2024 9:10am
Karlp606
Hi yes just checked my repair and draining all okay, I think it may be water getting in from where the rubber seal opens for the Boot hook arm that retracts into the body then dripping back through that hole, I'll get a photo up
Fri Sep 27 2024 12:11pm
Karlp606
