Home > Technical > L320 random DSC error at start up
Greg_B
Poland 2008 Range Rover Sport TDV8 HSE Java Black
Hello
I noticed different warning indicators sequence at truck start up and today I captured it during commuting for some shopping:
1. 6:60 AM - first start in the mornig:HDC and DSC stays on for a while, no warning messages
2. 7:09 AM - second start after few kilometers later - all good:
3. 7:34 AM - third start after another few kilometers - all good
4. 7:44 - fourth start - after washing the car - DSC and warning message - unfortunatel can't e seen - the final message was "Special programs off" - but quickly disapered
5. 7:45 - fifth start just after previous one - all good
Any idea what could be the reason of such behaviour? Could it be a weak battery?
Bests
Greg
Post #644304 Wed Sep 18 2024 5:34pm
Check the battery as a first step. Check it engine on and engine off. Ideally leave it to stand for 12 hours minimum after engine run before checking it with the engine off as it will have surface charge from the engine being run and this will give a falsely high reading. 2012 SDV6 - it's missing a couple of cylinders
Post #644306 Wed Sep 18 2024 6:40pm
Greg_B
Looks like it's battery. I measured it while cranking and it's not good... when ignition is on voltage drops to 11.75V, at cranking it drops to 9.75V. Need to check the battery at service then.
https://www.youtube.com/shorts/8s4GWwKE780
Post #644311 Thu Sep 19 2024 7:01am
Get a decent smart charger on it and try to get it charged - 11.75V is about 20% charged and using it at that level will surely damage it. If you can't get it to charge and hold good charge then it's new battery time.
Your usage isn't helping the battery. Several starts and short journey one after the other isn't giving the battery/generator time to recharge. 2012 SDV6 - it's missing a couple of cylinders
Post #644312 Thu Sep 19 2024 10:06am
Greg_B
update: smart charger for AGM batteries ordered, waiting for delivery
the battery fitted in the car is moll agm start/stop 81095 12V 95Ah 850A. it looks like it's 4 years old.
Post #644326 Fri Sep 20 2024 6:48am
