![]() | Home > Faults & Fixes > L320: Gear change hesitation |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 76 ![]() ![]() ![]() |
Thank you so much for this - I've just been out for a drive in mine after doing it and although the difference isn't huge, it's a most definite improvement.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
For want of a better description,, the Gearbox has a memory and it learns your driving style and changes gear accordingly, so if you drive like your granny it will change gear slowly. Having reset the Gearbox it will learn again, o drive it like you stole it and it will adapt to your new style of driving,,,,, or something along those lines. 2010 RRS, TDV8
Woody91 Member Since: 17 Feb 2024 Location: Norfolk Posts: 12 ![]() ![]() ![]() |
Agreed, I'm just unsure of to what level it resets, as it's clearly not the same as proper adaptation reset via OBD.
I didn't realise this could be done without some type of diagnostic tool 2010 RRS, TDV8
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 204 ![]() ![]() ![]() |
Great tip, completely changed my drive!
