Home > Faults & Fixes > L494 Passenger Airbag Light
Davenport
After a bit of research my code reader will only see engine faults. Need something like an Autel or budget alternative to see the other codes with all the other ECU’s and CANBUS. long term it’d be a good purchase but can’t source new in time for the MOT from AliExpress.
Post #644258 Mon Sep 16 2024 9:03am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Fingers crossed it stays off for the MOT. Don't know if you managed to remove the terminals, if not here's a link that you may find uselful: -
https://www.rrsport.co.uk/gallery/albums/u...RATION.pdf
It's from the L405, but still spplicable
Post #644259 Mon Sep 16 2024 9:14am
Davenport
Cheers checked out of a lot of YouTube on de-pinning. I’m going for that and the white vinegar with one of the kids fine paintbrushes (then hairdryer). It’s not on at the start of a journey comng on after a few minutes suggesting to my mind a moody connection
Post #644260 Mon Sep 16 2024 9:20am
2 RRS
Certainly worth a try, ideally you need a code, but worth a try none the less, perhaps try a bit of the Mrs nail varnish remover in case there is any oxidation on the contacts, shouldn't be as they are gold plated, but won't do any harm.
Post #644261 Mon Sep 16 2024 9:23am
Davenport
Crunch time for MOT loomed and without a decent code reader opted for a well trusted auto electrician who came up trumps. Turned out the issue was faulty continuity through the drivers seat connector. After splicing out the connector, soldering, shrink wrap and wrapping I’m code free at last.
A note to others really explore each seats connectors which I didn’t
Post #644459 Sat Sep 28 2024 6:54pm
2 RRS
So basically, right fix, wrong seat!! I did think it odd it was the passenger seat you were focusing on, as it's normally the drivers seat that gets most movement. On the plus side, you know the passenger seat will never play up now Very Happy
Post #644461 Sat Sep 28 2024 7:28pm
Davenport
Yes sort of barking up the wrong tree or seat in this case! With my man maths the fix (£65)was ultimately cheaper than most budget scanners (still getting a launch 123e though)
Nice to have no lights on… hopefully for a significant period
Post #644462 Sat Sep 28 2024 7:40pm
