![]() | Home > Tips & Tricks > L320 2012 SDV6 Diesel Injector Removal |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
I can usually remove the injectors with a little rotational movement and pulling up by hand. I’m not saying it’s easy, but it usually works for me. I’ve done the slide hammer fun as LR says, way more effort than a little twist and pull.
Carlos66 Member Since: 01 Feb 2024 Location: Adelaide Posts: 7 ![]() ![]() ![]() |
Many thanks Noexpert, I've heard that the injector pipes should be changed, Have you done this or just used the original ones, On the few ive removed on other vehicles I've never had a problem with it resealing. |
I’ve reused with no issues. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
I’ll add that if I’m reusing I unbolt the pipes from the injectors only, I leave the pipes attached to the fuel rails and remove them altogether as one unit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Did you find that the injector copper seals came out attached to the injectors or left in the holes, |
They’ve always come out with all the injectors I’ve removed. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
