Home > Technical > HSE TDV8 front passanger footwell duct installation
Greg_B
Poland 2008 Range Rover Sport TDV8 HSE Java Black
Hi All, I'm new to the Forum
I had to remove front passenger footwell duct. First I removed footweel trim but didn't remove the glovebox after that I removed the duct. Funny thing, but I can't put the duct back in place.
Maybe someone experienced the same and could give a hint how to do it? Will removing blow motor help?
Bests
Greg
Post #643866 Wed Aug 21 2024 4:58pm
Have you tried removing the liner/insert in the upper glovebox? might make it easier and see what you are doing.
Post #643875 Wed Aug 21 2024 10:13pm
Greg_B
Solved Smile
As I removed the duct few days ago I simply didn't remember in what orientation I got it out. I have been trying to put it back vertically, today I oriented it horizontally (the same orientation as mounted part) and I managed to put it back.
Hint: when dismounting something, take photos as human memory is volatile.
Bests
Greg
Post #643886 Thu Aug 22 2024 5:52pm
