Home > General (L494) > Heated Seats
g22mdb
Heated Seats
Hi all,
I've just purchased a 2018 L494 and I'm unsure whether I have a fault with my heated seats, or they're just not quite as good as other cars that I've owned! I have a small window of opportunity to get this resolved by the seller (private car dealer) if there's a fault.
It appears that neither seat will heat up unless a person is sat in them.
They also appear to heat up very slowly, around 15 minutes for the drivers seat to feel like it's "heated", and even when on +3 for a long period of time, it doesn't ever feel like it's too hot. Whereas previous cars have required lowering as it's felt too hot!
1) Is it by design that the seats do not get hot unless someone is in them
2) Are they generally this slow, and not that hot, or is there a heating element problem on both seats
Any help/input would be much appreciated!
Thanks,
Mike
Post #643790 Sat Aug 17 2024 7:41am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Does you car have heated and cooled seats? If so I don’t think they have an element like normal heated seats. Mine has and also takes ages to heat up but I’m pretty sure it works on when the engine is warm. Not too sure if they only work when someone is sat in them but makes sense if they do.
Post #643799 Sat Aug 17 2024 3:43pm
g22mdb
Very good point - it only has heated seats, not cooled. I should have mentioned this in my original post!
I will try bringing the car up to temperature and then switching them on, to see what the warm up time is!
Thanks!
Post #643800 Sat Aug 17 2024 4:20pm
Johnrrs
If it has the heated seats and not cooled then you will have elements I would imagine so should heat up quicker. Leather seats also take a bit longer to heat up.
Post #643801 Sat Aug 17 2024 5:32pm
HaggisMan
I’ve had a 2018 RRS and currently have a 2021 one, both from brand new and both with heated (but not cooled) seats. In both cars the seats only ever get warm, never ‘hot’, and that’s at full setting (+3). They’re nowhere near as hot as on my wife’s Audi A5 or my previous cars, where you often have to turn them down if you don’t want to roast your chestnuts! Yours sound fairly like mine and I guess JLR’s heated seats just aren’t that good. The heated steering wheel though - that’s brilliant!!
Post #643804 Sat Aug 17 2024 7:48pm
Turdmon
I have heated only and never run them on 3.
On the occasional time that I do use them, I can tell they are on within the first minute or so and we only tend to really use them on 1.
Post #643818 Sun Aug 18 2024 5:01pm
g22mdb
Interesting! Sounds like maybe mine aren't to fault then, they're just not very good! I've come out of an F-Type where I think I was spoiled as they'd heat up within a couple of minutes and need turning down!
Mine is also originating from Glasgow! How could they not have prepared it for the Scottish winters?! Laughing
Post #643823 Mon Aug 19 2024 7:40am
g22mdb
Thanks! Do yours also function regardless if someone's in the seat?
Post #643824 Mon Aug 19 2024 7:42am
Turdmon
Without checking, I'm pretty sure they only work when someone is sat in them. I think the occupancy sensor allows them to be on, much the same as the seatbelt warning.
Post #643828 Mon Aug 19 2024 9:42am
Lindab
Mine heat up pretty quickly. I sometimes put the passenger side on full blast when the wife's onboard to see how long it takes for her to realise, Rolling with laughter & its only a few of minutes Censored Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #643829 Mon Aug 19 2024 10:02am
Chips
I have a 21 plate non cooled seats and the heating is luke warm at best. Told landrover who replaced the elements under warranty but still no better ! previous 18 plate was fine as is our 17 plate disco.
We had a 16 plate first which had heated and cooled, so no element but blown warm air. That took an age to warm up but then was way too hot even on setting one and so continuely had to switch them on and off on a long drive and so have avoided cooled seats ever since MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #643841 Mon Aug 19 2024 8:08pm
g22mdb
Thank you all! Your experience has been helpful in understanding whether there's a fault or not!
Post #643896 Fri Aug 23 2024 1:48pm
