Home > Technical > Aux battery
MikeBell36269
Aux battery
Does the 2010 l320 have an aux battery and if so where is it?
Thanks
Post #643664 Sat Aug 10 2024 12:16pm
gogsy1956
Mine certainly doesn't 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #643671 Sat Aug 10 2024 8:59pm
On the face-lift L320, the space is partly filled with other stuff but I think you could still fit a small aux battery in there. It's in front of the brake master cylinder under the black plastic cover that matches the battery cover.
On warm-climate models, the aux battery goes where the FFBH is at the front of the engine bay on cold climate models.
The original L320 had a larger space in front of the master cylinder and a reasonable aux battery could be installed (and it's even designed for it with preinstalled threaded battery bracket locations, etc.). 2012 SDV6 - it's missing a couple of cylinders
Post #643674 Sun Aug 11 2024 11:18am
MikeBell36269
Thanks for the info, didn't think that it could have one as standard.
Post #643689 Sun Aug 11 2024 7:59pm
