Home > Maintenance & Modifications > Roof break light - remover?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. The rear roof brake light has become distorted, presumably due to the sun. I have a replacement. My question is....if I remove just the upper central panel trip in the boot (as in the picture) will I be able to get to all the "bits" to enable removal of the light fitting? If so do I just use force to remove the trim panel?!? Andrew Kennedy
Post #643253 Sun Jul 14 2024 3:05pm
Sadly done from the outside!
Remove the rear spoiler (some torox bolts) and plastic 10mm nuts I think in the glass section.
Disconnector washer pipe and cable.
Spoiler off, and now change the brake light
Post #643254 Sun Jul 14 2024 4:14pm
andrew kennedy
Andy - When you say "sadly done from outside" are you referring to having to remove all the trim in the boot upper section before I can get to take off the spoiler? If so, dose the trim simple pull off i.e. held on with clips? Andrew Kennedy
Post #643257 Sun Jul 14 2024 6:19pm
No trim removal required.
It’s all done from the outside.
Post #643258 Sun Jul 14 2024 6:56pm
Easy as.
https://drive.google.com/file/d/1A8H6QD0aJ...sp=sharing
Post #643259 Sun Jul 14 2024 9:28pm
andrew kennedy
Roof brake light removal
Well. thanks both for your input re removing the parts for getting at the roof brake light - seems my car is not fitted out as a standard 2006 model?!?
There are no visible bolts or anything like the pictures or a video I have looked at for a 2006 model.
If you have a look at the two attached pixs (not an easy area to take a photo) you will see, the only bolts up in that area are for taking off the boot lid. It seems to me I probably need to remove the bulky trim that encompasses the area all round the inside of the boot lid - if that is the next step, how do I remove the trim? Brute force and ignorance??! Andrew Kennedy
Post #643274 Mon Jul 15 2024 2:10pm
rear cols procedure carefully.
You need to lift the small glass only opening first. Undo the torx.
Close carefully, supporting the spoiler.
Then open the full tail gate to undo the plastic nuts
Post #643278 Mon Jul 15 2024 4:04pm
andrew kennedy
The penny has dropped!! It doesn't help being dyslexic. I'll sort it tomorrow. Bastille Day hear in France Andrew Kennedy
Post #643280 Mon Jul 15 2024 4:16pm
