Home > Technical > Camshaft sensor location L320 2.7l
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Have it booked for a diagnostic on wed am...But have been told that the crank sensor code can mask a CAMSHAFT sensor failure .
So where the ???? is the camshaft sensor ..or am I blind . told its easy to replace. Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #642962 Mon Jul 01 2024 1:21pm
In the link in your other threads, it shows that the gap iid can read the crank sensor speed. So I would like to think that would be conclusive.
To answer your question. Cam sensor is on the passenger side head at the front
The sensor is hidden at the side of the engine, held in with one bolt.
Post #642965 Mon Jul 01 2024 1:49pm
Pistnbroke
I have an i- carsoft reader and it did say camshaft P06633 but one garage has told me the crankshaft sensors rarely fail and a bad camshaft sensor can give a false reading ..who knows we shall see.
If its on the LHS its hiding very well as I cannot see it Always listen to old people or when they die you will live on in ignorance.
Post #642966 Mon Jul 01 2024 2:50pm
I think that shows live data
Look up crank and cam speed. See if you get numbers when cranking.
Post #642967 Mon Jul 01 2024 3:01pm
Pistnbroke
It still runs ...( until it stops) and yes will try live data Always listen to old people or when they die you will live on in ignorance.
Post #642968 Mon Jul 01 2024 3:04pm
I can see it in picture 10 here.
The black round thing sticking out the front.
https://www.ebay.co.uk/itm/175913116346?mk...media=COPY
Picture 8 shows the front , rear connector and bolt
Post #642969 Mon Jul 01 2024 3:06pm
Pistnbroke
Yes I clocked it ..in line with the oil pressure switch..will look tomorrow Always listen to old people or when they die you will live on in ignorance.
Post #642971 Mon Jul 01 2024 4:59pm
