Home > Technical > AIR CON
GrumpyPenguin
AIR CON
Up until today the air-con was working reasonably well.
Today, with the temperatures set to minimum the best I can get is warm air from any vents (warmer them ambient).
If I turn the air con off the warm air gets much hotter giving me the impression that hot air is being mixed in.
Any ideas please, I've tried nearly all the combinations of settings I can.
I have a two day trip planned, starting tomorrow - is there any way I can shut off the hot water supply as a temporary measure until I can get it sorted ?
Any help would be appreciated - TIA.
2005 RRS 2.7 V6
Post #642840 Tue Jun 25 2024 5:32pm
JonnyCJ
Had exactly the same this afternoon. Aircon was fully re-gassed a month or so ago and held a vacuum for 20mins before being pressurised.
It was about 35 degrees in the car at least and I noticed when switching the air con on the recirculate button illuminated. 20 mins of driving and it was still giving me very warm air out of the vents. Switched the recirculate button off and things seemed to cool down a bit, but still not really cold like I’d be expecting.
Luckily it’s now in the garage having the front crank oil seal replaced, so have asked them to investigate the air con as well.
I’ll report back, but be interested in thoughts from those more experienced on the L320 air con system than me.
Post #642841 Tue Jun 25 2024 5:56pm
You could try a hose clamp on the drivers side under the bonnet.
Read the fault climate codes
Post #642842 Tue Jun 25 2024 6:38pm
When was it last re-gassed? 2012 SDV6 - it's missing a couple of cylinders
Post #642843 Tue Jun 25 2024 7:34pm
gogsy1956
Condenser is a prime candidate,, happened on mine,, they have a habit of corroding along the bottom edge. Pulling a vacuum for 20 mins is not a good test. Re-gas with a dye and any leaks will be easier to spot, also make sure it is filled to the correct charge or it will never work correctly. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #642844 Tue Jun 25 2024 7:57pm
GrumpyPenguin
I could try clamping off the "heater" hose but have not got a clue which one it is.
Also, the A/C fan is not running.
It was last re-gassed about a year ago.
It's booked in Friday at an air con specialist so I'll report back afterwards.
Post #642845 Tue Jun 25 2024 8:10pm
Which AC fan ?
Post #642846 Tue Jun 25 2024 8:23pm
gogsy1956
Compressor is easy enough to check and rules out a major part of the system,, you should be able to hear or see the clutch pulling in when your assistant switches the AC on. Even a small leak will empty the system in days 2010 RRS, TDV8
22" overfinch
Post #642847 Tue Jun 25 2024 9:08pm
These are variable compressors. So you don’t hear them click in and out.
Fill valves are a common leak point on these. Nice and cheap
Post #642848 Tue Jun 25 2024 9:14pm
JonnyCJ
Thanks all for the input - will see what the garage says.
Post #642854 Wed Jun 26 2024 8:50am
GrumpyPenguin
Thanks for all the input so far.
Gas is up to spec but the compressor is not running, nor is the fan - booked in next week for further diagnosis so will have to wait & see..
Post #642903 Fri Jun 28 2024 1:10pm
GrumpyPenguin
It looks like the compressor is faulty, so wallet prepared for emptying.
Post #642982 Tue Jul 02 2024 2:08pm
JonnyCJ
Mine’s a new condenser, £100 plus £30 regas at the local National Tyres. Worth investigating a used compressor ? Plenty around on eBay
Post #642983 Tue Jul 02 2024 2:13pm
