Home > General > Tow bar electrics
Simon1976
England 2008 Range Rover Sport TDV6 HSE Baltic Blue
Tow bar electrics
Hello, my left hand indicator on my tow hitch socket has just stopped working, I have checked the connections into the socket, from there it runs to behind the Lh rear light in the boot, still no flashing supply for indicator. From there it goes into the wiring harness? Any know where it goes or a location for a fuse for Lh tow hitch indicator
Thanks
Post #642293 Thu May 30 2024 7:25pm
It goes to behind the glovebox.
There is no seperate fuse
Post #642296 Fri May 31 2024 6:17am
NoExpert
Not entirely true, depends on the trailer wiring setup. Some (Genuine LR) have a small fuse block in the left rear under the cargo cover. This was done away with on 10-13.
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #642299 Fri May 31 2024 7:57am
Agreed. My old 08MY TDV8 had a fusebox in the boot as you indicate. My MY12 doesn't, it's just in the main fuse box. 2012 SDV6 - it's missing a couple of cylinders
Post #642300 Fri May 31 2024 8:04am
Trailer indicators never fused.
Straight back to cjb, to FET (probably has electronic automatically resetable fuse)
Post #642301 Fri May 31 2024 8:20am
Ah, good point. It's the "big" lights that have fuses isn't it. Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #642302 Fri May 31 2024 8:48am
