Home > General > Gearbox reset 4.2 supercharged |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
I think 160k miles you have had the life of a 2005 gearbox.
Thu May 16 2024 8:12am |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 |
Cheers Andy…
Thu May 16 2024 8:30am |
You can reset the adaptions with a gap iid.
Thu May 16 2024 9:18am |
Thanks again Andy.
Thu May 16 2024 11:26am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9007 |
If it's done 160k miles on the original oil then the torque converter clutch might be in poor shape too. Until you drive it properly you might not be able to tell. A "cattle grid" vibration under load is the classic sign that the TC needs to be replaced. You can reduce the symptoms using things like Dr Tranny but once the TC clutch is contaminated it's never going to be right. 2012 SDV6 - it's missing a couple of cylinders
Thu May 16 2024 1:41pm |
Thanks…I has not got the heavy vibration under load just the delay in engaging up and down.
Thu May 16 2024 3:44pm |
On the plus side I can sit in it on the drive and watch the James Bond movies via DVD left in by the previous owner.
Thu May 16 2024 3:46pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
Gearbox problerly wants a proper reset via gap tool then it's a case of driving it so it relearns as mentioned above.
Thu May 16 2024 4:12pm |
