You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > General (L494) > L494 Rear Lights Stop Light Not Working - Bulb or..
Karlp606
So my passenger brake light has stopped working do these have any sort of LED bulb inside or is it a full led board that cant be swapped so its new light unit I would need?
is this all the time or only sometimes? I had the same problem when the RR would turn off the rear lights if it didn't meet a resistance. I fixed my issue though by modifying the wiring.
Sun Aug 04 2024 5:04pm
Karlp606
Hi no I think the LED went so I bought some more in the end.
Mon Aug 05 2024 9:56am
iainlovatt
I would keep an eye out on the break lights just in case the car turns them off every now and again.
