Home > General > Rear disc splash plate part nrs please
JonnyCJ
If anyone is able to look up the part numbers that would be appreciated. There’s some on eBay, but apparently they don’t fit MY10.
Got some for the front and double primed and triple painted them. The factory coating is a light coat of black with no primer. Designed to fail in a couple of years.
My rears are like a doily, for those old enough to remember what one is.
Many thanks !
Post #641730 Sun May 05 2024 7:42pm
To replace the rear one's you have to pull the rear hubs I think, but there aftermarket one's that are made two piece so no need to pull hubs to replace them, not sure where you can buy them in the UK though.
Post #641741 Mon May 06 2024 7:56am
JonnyCJ
Thanks Col - will do some more Googling
Post #641743 Mon May 06 2024 8:12am
JonnyCJ
Found them - the eBay ones do fit, but necessitate taking off the rear hub and replacing the rear bearings, so quite a faff. Will chat with my Indy when it goes in tomorrow and see what the likely cost is.
The 2 piece ones are only available at Atlantic British in the US and part of a rear brake refurb kit with new shoes etc. also prohibitively expensive once you factor in shipping and customs.
Post #641746 Mon May 06 2024 10:01am
