Home > General > Things I’ve done on my RRS today |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 416 |
Aside from test flying and fixing our balsa glider after a nose heavy crash, Sam and I got to work on making the media interface solution a little neater than have a cable trailing from the centre glove box/fridge unit to where the iPhone sits on the vent above the start/stop button.
Mon May 06 2024 7:16pm |
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 |
where do you mount your phone? The only 'regressive' element of my change from L320 2007 to L320 2013 is the fact that my IPhone no longer has its own shelf in front of the satnav....
Thu May 09 2024 4:04pm |
I have a Yosh magnetic mount on the vent. The phone sits just above the start/stop button and is held at the same angle as the vent. It sits flush and very neat and the charging lead is the perfect length to go into the bottom of the phone, without having too much cable hanging loose. |
Thu May 09 2024 8:02pm |
Cheers, I'll check that out ... my vent mount doesn't seem up to the job of hanging onto an iPhone 12 pro max! Suspect it was an el cheapo from somewhere |
Thu May 09 2024 8:13pm |
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 64 |
I've been using Brodit mounts for well over thirty years and IMO they're the best on the market.
Fri May 10 2024 8:31am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Second the Brodit mounts one of the best, used one to mount a portable tomtom sat nav as well.
Fri May 10 2024 9:52am |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 161 |
Another for Brodie
Fri May 10 2024 2:20pm |
That's the same one I use, so I don't have to take a picture now - thanks.
Fri May 10 2024 3:47pm |
Here’s my Yosh magnetic vent holder and phone in place. Really unobtrusive and the phone has never fallen off.
Fri May 10 2024 5:00pm |
I used the other style brodit mount, obstructs the vent slightly but nothing drastic.
Fri May 10 2024 10:42pm |
All, many thanks for the tips / pics on the phone mount ..... a little package from Brodit should be arriving today |
Fri May 17 2024 6:53am |
Fri May 17 2024 5:19pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
I put a new battery in. Car hasn't moved since Christmas and it started immediately. Took a few miles to get any sensible brakes back!
Sat May 18 2024 2:39pm |
