![]() | Home > General (L461) > Advice needed, please...Should I buy an RRS? |
Tizzy Member Since: 30 Dec 2023 Location: Leicestershire Posts: 35 ![]() ![]() |
Some love the hybrids, some don’t, there are beginning to be some reports of HV heater failures, which blighted the old P400e - mine had three replaced! That said the EV range is very good. IMHO Autobiography now isn’t worth the premium as the Dynamic SE is a much better spec than the previous model. If you want Cooled/massage seats and an opening pan roof, plus soft close and the better sound system get the AB but I’ve had several in the old model and don’t feel short changed in an SE Dynamic now. I’d check your insurance, mine with NFU actually went down when I moved from the P400e to the D300 Dynamic SE and is c. £860, 55 years old, full no claims and rural location, behind electric gates and garaged. Hope that helps. |
Seapaddler Member Since: 03 May 2024 Location: Anglesey Posts: 4 ![]() ![]() |
Thank you, Tizzy. That’s very helpful information.
Morning, on wheels again a very personal thing. I suspect most on here would say avoid the 23’s - just way too big and style over substance. I had a demo loan D300 on 22’s for two weeks, it looked good, but the ride was harder than my P400e on 21’s so I spec’d my new D300 with the 21’s which are dark grey on the black pack. They have a noticeably higher sidewall which gives a noticeably better ride especially over ridges and bad road surfaces - so basically the UK! No obvious difference in handling, though I don’t drive it hard - we have a JCW Mini for that! Trade off I guess is a little on the looks some might say it looks slightly under-wheeled. Personal choice. The only thing to note is that AB comes on 22 as standard, and also strangely on the 21 you get Michelin Premacy tyres OE fit, rather than Pirelli Scorpion Zero, which I’d have preferred to be honest as I have always found them to be a great tyre and very long lifed. |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 310 ![]() ![]() |
Morning, we have ordered a d300 dynamic SE with quite a few extras, as previously mentioned on here they are very well specked as standard, on the wheels my current p400e is on 21’s and I do find it rolls a bit on cornering even in dynamic mode, compared to my 2 previous L494s that were on 22’s, we have taken the 23’s but they didn’t feel that bad to me compared to the 22’s on another car we test drove.
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
I have 22s in England with no issues BUT the roads in Wales generally are far better maintained than here and if most of your mileage is there - no problems! 2017 3.0 SDV6 HSE |
Thanks all Very helpful stuff.
RabJ Member Since: 06 May 2024 Location: Ballymena Posts: 16 ![]() ![]() |
Be very carefull to test drive one at speed. I saw a couple of reports about steering loading up a lot at speed, 60 70 mph and unfortunatly dismised them. I now fimd my one week old Dynamic SE firms up so much at motorway speeds that it takes quite a bit of effort to input small corrections to the steering. I havent heard anyone else on here say anything about it , so either its a fault on some cars or I'm just to sensitive. Either way content yourself before buying. |
Little trick I’ve discovered on Motorways - put it into Comfort mode (I leave mine in Auto TR all the time) in Comfort it smoothes out the motorway ridges and crucially lightens the otherwise heavy steering. |
