Home > Faults & Fixes > Air suspension Fault
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
An interesting one, the wife's MY10.5 3 litre Oil burner air suspension has in the last few days started to
play up, when she selects "access mode/height" the vehicle starts to lower and then raises to off road
height, stating check for obstructions or something similar.. I just wondered if this means it has a dodgy
sensor rather than the air compressor ?? as it seems to rise ok when it determines falsely there is
something stuck underneath..
Anyone else had this?? Just doing some research/checks before handing it over to our local independent
who has had enough dosh off us in the last 14 months (AC compressor, Alternator, rocker/manifolds
replaced, oil cooler replaced Big Cry ) Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #641241 Thu Apr 18 2024 4:42am
gogsy1956
A few codes would help to narrow things down but at a guess it could be a ride height sensor or if you are still on the original compressor,, a blocked exhaust valve. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #641267 Thu Apr 18 2024 8:05pm
