Home > General (L494) > 2017 RRS HSE Battery
Rjgordon0
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Hey Guys I’m not sure which way to turn here, my dash keeps coming up with a low battery warning. I get that, as the stop start has stopped working so I guess the battery will need replacing. All the places I have googled tell me there are two batteries (like my wife’s E220). I cannot find an auxiliary battery anywhere on the car so do I only have one battery with the stop/start facility?
TIA
Post #640169 Tue Mar 05 2024 3:58pm
scrumps
Hi,
Look here, https://www.rrsport.co.uk/forum/topic57326...94+battery but also check the security of the earth cable in the spare wheel well.
I had LRE out to my 16MY AB for low battery issues and the guy went straight to the boot!
Seems like it (was) a regular problem.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #640170 Tue Mar 05 2024 4:26pm
Rjgordon0
Hi, thanks for that but your link is the same as I’ve seen before & I have no auxiliary battery behind that panel in the boot. There are a lot of electrical components but no battery!!
Post #640171 Tue Mar 05 2024 4:35pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
You will have a capacitor not a battery for the stop start system. It’s the early L494s that had battery for the stop start
Post #640172 Tue Mar 05 2024 5:23pm
b1ecc
United Kingdom 2013 Range Rover Sport SDV6 HSE Izmir Blue
I have 2016 RRS and only have one battery, changed it last year after the low battery warning.
Post #640173 Tue Mar 05 2024 5:24pm
Johnrrs
Your main battery may need charging up or replacing. I had mine replaced around 2 month ago at a cost of £285 ish. It’s located under the spare wheel in the boot. If you charge your existing battery it will also charge up the capacitor (or battery on early models)
Post #640175 Tue Mar 05 2024 5:26pm
Rjgordon0
Hi, thanks, I realise this now !😎
Post #640178 Tue Mar 05 2024 6:13pm
Nick900
I would fit this from Tayna did so about a year ago and works perfectly with a 4 year warranty.
https://www.tayna.co.uk/car-batteries/powerline/019agm/
Post #640180 Tue Mar 05 2024 7:36pm
