Home > Technical > Range Rover Sport SDV6 Injectors coding
pantheo91
Greece 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Hello everyone,
I have a Range Rover Sport L494 SDV6 3.0L engine with the injectors knocking - tapping. I read the injector code imported to the ECU on each cylinder and doesn't match the ones that are on ECU. While i am trying to import the codes that are on each injector on each cylinder i get an error (10 Digit code) on the head while importing the old ones was successfully imported.
My injectors are bosch ones with the part number 0445117053. I think i am missing something here or the previous owner replaced the injectors without coding them to the ECU. Or if there is some kind of Bosch injector decoder to get the right ECU codes of my injectors
My question is that how can i find the correct code to import to the ECU of each specific injector. For example on of my injectors have the code 07F181C058 on the head.
Thanks in advance
Post #640099 Fri Mar 01 2024 6:47pm
