Home > General > Brake fluid leak
loonyball
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
Brake fluid leak
Hello all, couple of days ago i noticed the footbrake became a bit spongy, then the “HDC not available” “invalid data from dynamics module” warning along with three yellow light on dash (see pic) cleared codes with my iid tool, drove car and after 50 yards lights on again, put car on ramps and found a brake pipe leaking fluid at the rear drivers side wheel just above the disc, my question is would the fluid leak and soft brake pedal cause the warnings and light on the dash ?
Thanks 👍. (07 sport 2.7)
Post #639990 Sun Feb 25 2024 10:08pm
As it all started around the same time logic tells me, repair the leak, bleed the brakes, clear the codes and see what happens, rather than get excited about faults that may not be a separate issue.
Post #639991 Sun Feb 25 2024 10:20pm
