Home > General (L494) > L494 2014 STEERING LOCKED
jaxx
Spain 2013 Range Rover Sport SDV6 HSE Santorini Black
In A Bind, installed new batteries, discovered Ground wire conection under wheel arch corroded , cleaned it up and when i tried to start up it gave me loads of faults and Steering Locked, i cant move the car
please help if you can
thanks
George
RRS 2014 L494
Post #639861 Wed Feb 21 2024 9:16pm
As a first step, I would say disconnect the battery, and leave it like that for about an hour.
then reconnect and see what happens. --
Post #639882 Thu Feb 22 2024 1:04pm
jaxx
Thanks for your advice,
I had thought i repaired the Ground fault however, after that, the same problems where there only i now had the locked steering
I then stripped the wheel and the arch covers off and i found that the Ground Post connection was broken.
i removed the plastic frame or cartridge it was in then drilled and tapped a m6 thread in the ground post then bolted the ground wires to it. That was it, car fired up steeting unlocked and all fault errors gone , what a relief for sure,
thanks
Grorge
Post #639912 Fri Feb 23 2024 6:56am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Great result
Post #639929 Fri Feb 23 2024 9:01pm
