![]() | Home > Technical > Front wipers stopped working |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Park switch is inside the motor .It keeps the blades powered even when you turn the wipers off until the blades reach the park position then it turns off the motor and puts the brakes on by shorting the motor out . Always listen to old people or when they die you will live on in ignorance.
